ftp
Enables File Transfer Protocol (FTP) on this management policy. FTP is the
standard protocol for transferring files over a TCP/IP network. FTP requires
administrators enter a valid username and password authenticated locally. FTP access is
disabled by default.
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
ftp {password|rootdir|username}
ftp {password [1 <ENCRYPTED-PASSWORD>|<PASSWORD>]}
ftp {rootdir <DIR>}
ftp {username <USERNAME> password [1 <ENCRYPTED-PASSWORD>|<PASSWORD>] rootdir <DIR>}
Parameters
ftp password |
Optional. Configures the FTP server password |
1 <ENCRYPTED- PASSWORD> |
Configures an encrypted password. Use this option when copy pasting the
password from another device.
- <ENCRYPTED-PASSWORD> – Specify the password. The password
should not exceed 63 characters in length.
<PASSWORD> |
Configures a clear text password |
ftp {rootdir <DIR>}
ftp rootdir <DIR> |
Optional. Configures the root directory for FTP logins
- <DIR> – Specify
the root directory path. By default the root directory is set to
flash:/
ftp username <USERNAME> |
Optional. Configures a new user account on the FTP server. The FTP user
file lists users with FTP server access.
- <USERNAME> –
Specify the username. The username should not exceed 32 characters in
length.
password [1 <ENCRYPTED-PASSWORD>|<PASSWORD>] |
- 1
<ENCRYPTED-PASSWORD> – Specifies an encrypted password (use this
option if copy pasting from another device). The password should not
- <PASSWORD> -
rootdir <DIR> |
After specifying the password, configure the FTP root directory.
- rootdir <DIR> –
Configures the root directory for FTP logins. Specify the root
directory path.
Usage Guidelines
The string size of an encrypted password (option 1, password is
encrypted with a SHA1 algorithm) must be exactly 40 characters. Copy paste the encrypted
password here.
nx9500-6C8809(config-management-policy-test)#ftp username superuser password test@123 rootdir dir
nx9500-6C8809(config-management-policy-test)#show context
management-policy test
http server
ftp username superuser password 1 f617ca50c59fb47028f96db4baab5f3d8f03c03ab257960b0fd127c69f02cd7e rootdir dir
no ssh
aaa-login radius external
aaa-login radius policy test
banner motd "Have a Good Day"
Related Commands
no
Disables FTP and its settings, such as the server password, root
directory, and users |
