Configures the server type and interval at which interim accounting updates are sent to the server. Up to 2 accounting servers can be configured.
This feature tracks user activities on the network, and provides information, such as resources used and the usage time. This information can be used for audit and billing purposes.
TACACS accounting tracks user activity and is useful for security audit purposes.
accounting [access-method|auth-fail|commands|server|session]
accounting access-method [all|console|ssh|telnet] {(console|ssh|telnet)}
         accounting [auth-fail|commands|session]
accounting server [<1-2>|preference]
accounting server preference [authenticated-server-host|authenticated-server-number| authorized-server-host|authorized-server-number|none]
accounting server <1-2> [host|retry-timeout-factor <50-200>|timeout]
accounting server <1-2> host <IP/HOSTNAME> {secret [0 <SECRET>|2 <SECRET>|
<SECRET>]} {port <1-65535>}
         accounting server <1-2> timeout <3-5> {attempts <1-3>}
         | access-method | Configures TACACS accounting access mode. The options are: console, SSH, Telnet, and all. |
| all | Configures TACACS accounting for all access modes |
| console | Configures TACACS accounting for console access only |
| ssh | Configures TACACS accounting for SSH access only |
| telnet | Configures TACACS accounting for Telnet access only |
| auth-fail | Enables accounting for authentication fail details. This option is disabled by default. |
| commands | Enables accounting of commands executed. This option is disabled by default. |
| session | Enables accounting for session start and stop details. This option is disabled by default. |
| server | Configures a TACACS accounting server |
| preference | Configures the accounting server preference (specifies the method of selecting a server, from the pool, to send the request) |
| authenticated-server-host | Sets the authentication server as the accounting server. This is the
                        default setting. This parameter indicates the same server is used for authentication and accounting. The server is referred to by its hostname.  |
| authenticated-server-number | Sets the authentication server as the accounting server This parameter indicates the same server is used for authentication and accounting. The server is referred to by its index or number.  |
| authorized-server-host | Sets the authorization server as the accounting server This parameter indicates the same server is used for authorization and accounting. The server is referred to by its hostname.  |
| authorized-server-number | Sets the authorized server as the accounting server This parameter indicates the same server is used for authorization and accounting. The server is referred to by its index number.  |
| none | Indicates the accounting server is independent of the authentication and authorization servers |
accounting server <1-2> retry-timeout-factor <50-200>
| server <1-2> | Configures an accounting server. Up to 2 accounting servers can be configured |
| retry-timeout-factor <50-200> | Sets the scaling factor for retry timeouts
 A value of 100 indicates the time gap between two consecutive retires remains the same irrespective of the number of retries. A value lesser than 100 indicates the time gap between two consecutive retries reduces with each successive retry. A value greater than 100 indicates the time gap between two consecutive retries increases with each successive retry.  |
| host <IP/HOSTNAME> | Configures the accounting server‘s IP address or hostname |
| secret [0 <SECRET>| 2 <SECRET>| <SECRET>] | Optional. Configures a common secret key used to authenticate with the
                        accounting server
| port <1-65535> | Optional. Configures the accounting server port (the port used to
                        connect to the accounting server)
| timeout <3-5> | Configures the timeout for each request sent to the TACACS accounting
                        server. This is the time allowed to elapse before another request is sent to
                        the TACACS accounting server. If a response is received from the server
                        within this time, no retry is attempted.
| attempts <1-3> | Optional. Specifies the number of times a transmission request is
                        attempted. This is the maximum number of times a request is sent to the
                        TACACS accounting server before getting discarded.
nx9500-6C8809(config-aaa-tacacs-policy-test)#accounting auth-fail
         nx9500-6C8809(config-aaa-tacacs-policy-test)#accounting commands
         nx9500-6C8809(config-aaa-tacacs-policy-test)#accounting server preference
         nx9500-6C8809(config-aaa-tacacs-policy-test)#show context aaa-tacacs-policy test accounting server preference authorized-server-number accounting auth-fail accounting commands nx9500-6C8809(config-aaa-tacacs-policy-test)#
| no (aaa-tacacs-policy-config-mode-command) | Resets values or disables commands |
