peer
Configures peer(s) allowed to establish the manual session. The peers are identified by their IP addresses.
Syntax
peer ip-address <IP> {udp {port <1-65535>}}
Parameters
Configures the session peer's IP address in the A.B.C.D format
udp {port <1-65335>}
Optional. Configures the UDP encapsulation mode for this session (default encapsulation is IP)
  • port <1-65535> – Optional. Configures the peer‘s UDP port running the L2TPv3 service.
    • <1-65335> – Specify a value from 1 - 65535.
nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#peer ip-address 5.6.7.8 udp port 150
nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#show context
 l2tpv3 manual-session test
  local-cookie size 8 200 300
  local-ip-address 1.2.3.4
  mtu 200
  local-session-id 1
Related Commands
no
Removes the manual session‘s peer configuration
