AP5010 Specifications
            The AP5010 is a high-performance 802.11ax Wi-Fi 6E, 6 GHz, 5 GHz band, and 2.4 GHz
                band access point designed for high-density indoor environments. The access point
                supports IEEE 802.11ax Orthogonal Frequency-Division Multiple Access (OFDMA)
                multi-user access.
            The access point can be installed indoors on a ceiling rail, on a nonstandard
                ceiling, or on a wall.
                - One multicolor LED status
                    light
                - One light sensor located at the
                    top of the device
                - Two Ethernet ports - Eth0 and
                        Eth1
Ethernet ports (Eth0 and Eth1) automatically negotiate full-duplex
                        connections with the connecting device.
                            - Eth0 is 5/2.5/1GE/100
                                with Power over Ethernet (PoE)
                            - Eth1 is 2.5/1GE/100
                                with PoE power sourcing equipment (PSE)
These ports are auto-sensing and adjust to straight-through and
                        crossover standard Cat6 or better Ethernet cables automatically. The access
                        point receives power through an Ethernet connection to the ETH0 port from
                        PSE that is compatible with the 802.3bt and 802.3at standards.
                - One USB port
Use the USB port
                        to connect USB-based beacons such as iBeacon and Internet of Things (IoT)
                        devices. Remove the protective cover to access the USB port.
                - One micro USB console port
                - One reset button
                - One Kensington lock
The best
                        practice is to use Kensington locks for locking the device.
