wan-metrics down-speed <0-4294967295> up-speed <0-4294967295>
                         wan-metrics  |
                         Specifies the WAN metrics for the up and down traffic  |
                         down-speed <0-4294967295>  |
                         Configures the down stream traffic speed
                         up-speed <0-4294967295>  |
                         Configures the up stream traffic speed
nx9500-6C8809(config-passpoint-policy-test)#wan-metrics down-speed 2000 up-speed 2000
         nx9500-6C8809(config-passpoint-policy-test)#show context passpoint-policy test access-network-type chargeable-public connection-capability ip-protocol 2 port 10 closed nai-realm example eap-method 1 ttls auth-param vendor hex 00001E eap-method 2 rsa-public-key auth-param credential cert net-auth-type accept-terms url www.test.com operator name exampleoperator roam-consortium hex 223344 venue group assembly type coffee-shop venue name testShop wan-metrics down-speed 2000 up-speed 2000 3gpp mcc 505 mnc 14 osu ssid test osu provider test name testOSU method soap-xml-spp priority 2 nai test.org server-url test.exampe.com nx9500-6C8809(config-passpoint-policy-test)#
| no |
                         Removes the WAN metrics configuration on this passpoint policy  |
