Use the config-profile-<DEVICE-PROFILE-NAME> mode to configure Ethernet, VLAN and tunnel settings.
To switch to this mode, use the following commands:
<DEVICE>(config-profile-default-<DEVICE-TYPE>)#interface [<INTERFACE-NAME>| fe <1-4>|ge <1-24>|me1|port-channel <1-4>|pppoe1|radio [1|2|3]|up1|vlan <1-4094>| wwan1|xge <1-24>]
The following example uses the config-profile-nx9500-6C8809 instance to configure a VLAN interface:
nx9500-6C8809(config-profile-default-nx5500)#interface vlan 8
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#?
SVI configuration commands:
crypto Encryption module
description Vlan description
dhcp Dynamic Host Configuration Protocol (DHCP)
dhcp-relay-incoming Allow on-board DHCP server to respond to relayed DHCP
packets on this interface
ip Interface Internet Protocol config commands
ipv6 Internet Protocol version 6 (IPv6)
no Negate a command or set its defaults
shutdown Shutdown the selected interface
use Set setting to use
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
The following table summarizes interface VLAN configuration commands:
| Commands | Description |
| crypto | Defines the encryption module used with this VLAN interface |
| description | Defines the VLAN interface description |
| dhcp | Enables inclusion of optional fields (client identifier) in DHCP client requests |
| dhcp-relay-incoming | Allows an onboard DHCP server to respond to relayed DHCP packets on this interface |
| ip | Configures the VLAN interface‘s IP settings |
| ipv6 | Configures the VLAN interface‘s IPv6 settings |
| no | Removes or reverts this VLAN interface‘s settings to default |
| shutdown | Shuts down this VLAN interface |
| use | Associates an IP (IPv4 and IPv6) access list, bonjour-gw-discovery policy, and an IPv6-route-advertisement policy with this VLAN interface |
