At least one default area, bearing number ‘0‘, should be configured for every OSPF network. In case of multiple areas, the default area 0 forms the backbone of the network. The default area 0 is used as a link to the other areas. Each area has its own link-state database.
A router running OSPF sends hello packets to discover neighbors and elect a designated router. The hello packet includes link state information and list of neighbors. OSPF is savvy with layer 2 topologies. If on a point-to-point link, OSPF knows it is sufficient, and the link stays up. If on a broadcast link, the router waits for election before determining if the link is functional.
area [<0-4294967295>|<IP>]
area | Defines an OSPF area |
<0-4294967295> | Defines an OSPF area in the form of a 32 bit integer
<IP> | Defines an OSPF area in the form of an IP address
nx9500-6C8809(config-profile default-ap8533-router-ospf)#area 4 nx9500-6C8809(config-profile default-ap8533-router-ospf-area-0.0.0.4)#? Router OSPF Area Mode commands: area-type OSPF area type authentication Authentication scheme for OSPF area no Negate a command or set its defaults range Routes matching this range are considered for summarization (ABR only) clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile default-ap8533-router-ospf-area-0.0.0.4)#
nx9500-6C8809(config-profile default-ap8533-router-ospf-area-0.0.0.4)#show context area 0.0.0.4 nx9500-6C8809(config-profile default-ap8533-router-ospf-area-0.0.0.4)#
Command | Description |
area-type | Configures a particular OSPF area as STUB or NSSA |
authentication | Specifies the authentication scheme used for the OSPF area |
range | Specifies the routes matching address/mask for summarization |
no (area-config-mode-command) | Removes this area settings |
no (router-mode-config-command) | Removes this area configuration from the router mode policy |
