Creates an application group and enters its configuration mode. An application group is a collection of system-provided and/or user-defined applications. It is a subset of the total number of supported applications. Use this command to create and application group. It is always easier to create deny and allow rules that can be collectively applied collectively to a group of applications rather than creating rules for individual applications.
Application group is a means of selectively denying or allowing access to set of applications within a specific app-category.
The WiNG 7.1.X release does not support DPI (application visibility) on AP5XX model access points.application-group <APPLICATION-GROUP-NAME>
application-group <APPLICATION-GROUP-NAME> | Creates an application group and enters its
configuration mode
nx9500-6C8809(config)#application-group amazon nx9500-6C8809(config-app-group-amazon)#? Application Group Mode commands: application Add application to group description Add application-group description no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-app-group-amazon)#
no | Removes an existing application group |
