guest
Configures this group as a guest (non-management) group. A guest user group has temporary permissions to the controller‘s local RADIUS server. You can configure multiple guest user groups, each having a unique set of settings. Guest user groups cannot be made management groups with access and role permissions.
Guest users and policies are used for captive portal authorization to the network.
Syntax
guest
Parameters
None
nx9500-6C8809(config-radius-group-test)#guest
nx9500-6C8809(config-radius-group-test)#show context
radius-group test
 guest
Related Commands
no
Makes this group a non-guest group
