Creates a Purview Application Group and enters its configuration mode. A Purview application group is a collection of system-provided and/or user-defined application definitions. Application group allows you to enforce mandatory stats reporting for specific traffic types.
Extreme Network's AP5xx model APs, running WiNG 7.1.2 and later versions of the WiNG 7 OS, use ExtremeAnalytics for ExtremeCloud IQ - Site Engine (Purview™) libDPI engine to implement Application Visibility and Control (AVC) within a managed network. libDPI detects top-level hosting applications along with the services these applications host.
Legacy WiNG devices, running WiNG 5.9.X or WiNG 7.2.1 do not support Purview libDPI engine. Legacy WiNG devices use a third-party, DPI engine to enforce AVC within the managed network. For more information on configuring AVC on legacy devices, see application-policy and application-group.These legacy devices are: AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432, AP8533, NX500, NX7500, NX9500, NX9600 and VX9000.
purview-application-group <PURVIEW-APP-GROUP-NAME>
purview-application-group <PURVIEW-APP-GROUP-NAME> | Creates a Purview application group and enters its configuration mode
If the required application definition is not system-provided, create a custom application signature. For information on creating custom application signatures, see applicationnx9500-6C8809(config)#purview-application-group PurvAppGrp nx9500-6C8809(config-purview-app-group-PurvAppGrp)#? Purview Application Group Mode commands: application Add application to group description Add application-group description no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-purview-app-group-PurvAppGrp)#
no (global-config-mode) | Removes an existing Purview application group |
application | Creates an application definition and enters its configuration mode. |
purview-application-policy | Creates a Purview application policy and enters its configuration mode. |
nsight-policy (global-config-mode) | Creates an NSight policy and enters its configuration mode. |
