local-ip-address
Configures the manual session‘s source IP address. If no IP address is specified, the tunnel‘s source IP address is automatically configured based on the tunnel peer IP address. This parameter is applicable when establishing the session and responding to incoming requests.
Syntax
local-ip-address <IP>
Parameters
  • <IP> – Specify the IP address in the A.B.C.D format.
nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test#local-ip-address 1.2.3.4
nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#show context
 l2tpv3 manual-session test
 local-cookie size 8 200 300
Related Commands
no
Resets the manual session‘s local source IP address. This re-establishes the session.
