interface-config-radio-instance
Configures the radio‘s mode of operation
This command sets the mode to either 2.4 GHz WLAN or 5.0 GHz WLAN support depending on the radio‘s intended client support.
Set the mode to sensor if using the radio for rogue device detection. The radio cannot support rogue detection when one of the other radios is functioning as a WIPS sensor. To set a radio as a detector, disable sensor support on the other access point radios.
rf-mode [2.4GHz-wlan|5GHz-wlan|scan-ahead|sensor]
| rf-mode | Configures the radio‘s mode of
                           operation Note: For
                           information on the possible modes of operations for
                           AP505 and AP510 radios, see Usage Guidelines.
| 2.4GHz-wlan | Provides WLAN service in the 2.4 GHz bandwidth |
| 5GHz-wlan | Provides WLAN service in the
                        5.0 GHz bandwidth Note: For
                           AP510 model access point, you can provide 5 GHz WLAN
                           support on both radio 1 and radio 2.
| scan-ahead | Enables this radio to operate
                        as a scan-ahead mode A radio functioning in the scan-ahead mode is used for forward scanning only. The radio does not support WLAN or mesh services. The scan ahead feature is used in DFS (Dynamic Frequency Selection) aware countries for infrastructure devices, static, and VMMs (vehicular mounted modems). It enables a secondary radio to scan ahead for an active channel for backhaul transmission, in the event of a radar trigger on the primary radio. The device then switches radios allowing transmission to continue. This is required in environments where handoff is required and DFS triggers are common. With a secondary radio dedicated for forward scanning, the primary radio, in case of radar hit, hands over the CAC (channel availability check) function to the secondary radio. This avoids a break in data communication, which would have resulted if the primary radio was to do CAC itself. The secondary radio periodically does a scan of the configured channel list, searching for the other available meshpoint roots. When configured on the root meshpoint, the scan-ahead feature also scans for cleaner channels. Note: rf-mode scan-ahead is not supported on the AP 505i
                           and AP510i model access points.
| sensor | Operates as a sensor radio.
                        Configures this radio to function as a sensor, providing
                        scanning services on both 2.4 GHz and 5.0 GHz bands. The
                        radio does not provide WLAN services. Following is the
                           sensor mode setting for AP505 and AP510:
 Note: For
| Option 1 | Radio 1: | Set to 2.4 GHz WLAN, Channels 1 - 11 in the 20 MHz /40 MHz bandwidths | |
| Radio 2: | Set to 5 GHz WLAN, Channels 36 - 165 in the 20 MHz /40 MHz /80 MHz /160 MHz | ||
| Option 2 | Radio 1: | Set to 5 GHz, Channels 36 - 64 in the 20 MHz /40 MHz /80 MHz /160 MHz bandwidths | |
| Radio 2: | Set to 5 GHz, Channels 100 - 165 in the 20 MHz /40 MHz /80 MHz /160 MHz bandwidths | ||
| Option 3 | Radio 1: | Set to Sensor | |
| Option 2 | Radio 1: | Set to Sensor. | |
| Radio 2: | Set to Sensor. | ||
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#rf-mode sensor nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 rf-mode sensor placement outdoor mesh client off-channel-scan channel-list 2.4GHz 1 guard-interval long aggregation ampdu tx-only aeroscout forward ekahau forward ip 172.16.10.1 port 3 non-unicast tx-rate bss 1 dynamic-all --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
ap505-134006(config-device-94-9B-2C-13-40-06-if-radio1)#rf-mode 2.4GHz-wlan
ap505-134006(config-device-94-9B-2C-13-40-06-if-radio2)#rf-mode 5GHZ-Wlan
ap505-13403B(config-device-94-9B-2C-13-40-38-if-radio1)#wlan wlan123 bss 1 primary
ap505-13403B(config-device-94-9B-2C-13-40-38-if-radio2)#wlan wlan123 bss 1 primary
ap505-134006(config-device-94-9B-2C-13-40-06)#show cont ap505 94-9B-2C-13-40-06 use profile default-ap505 use rf-domain default hostname ap505-134006 interface radio1 channel 1 wlan wlan123 bss 1 primary interface radio2 channel 36 wlan wlan123 bss 1 primary no adoption-mode ap505-134006(config-device-94-9B-2C-13-40-06)#..
ap505-134006(config)#commit wr mem [OK] ap505-134006(config)#show wi rad ------------------------------------------------------------------------------------- RADIO RADIO-MAC RF-MODE STATE CHANNEL POWER #CLIENT ------------------------------------------------------------------------------------- ap505-134006:R1 94-9B-2C-0E-88-80 2.4GHz-wlan On 1 ( 1) 14 (smt) 1 ap505-134006:R2 94-9B-2C-0E-88-90 5GHz-wlan On 36 ( 36) 16 (smt) 1 ------------------------------------------------------------------------------------- Total number of radios displayed: 2 ap505-134006(config)#
| no (radio-interface-config-command) | Resets the radio‘s mode of operation |
| data-rates | Configures the 802.11 data rates on this radio |
