To navigate to the automatic IPSec manual VPN tunnel configuration instance, use the following command:
In the device-config mode:
<DEVICE>(config-device-<DEVICE-MAC>)#crypto map <CRYPTO-MAP-TAG> <1-1000> ipsec-manual
In the profile-config mode:
<DEVICE>(config-profile-<PROFILE-NAME>)#crypto map <CRYPTO-MAP-TAG> <1-1000> ipsec-manual nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#3)# nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#3)#? Manual Crypto Map Configuration commands: local-endpoint-ip Use this IP as local tunnel endpoint address, instead of the interface IP (Advanced Configuration) mode Set the tunnel mode no Negate a command or set its defaults peer Set peer security-association Set security association parameters session-key Set security session key parameters use Set setting to use clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#3)#
The following table summarizes IPSec manual VPN tunnel configuration mode commands:
Command | Description |
local-endpoint-ip | Uses the configured IP as local tunnel endpoint address, instead of the interface IP (Advanced Configuration) |
mode | Sets the tunnel mode |
peer | Sets the peer device‘s IP address |
security-association | Defines the lifetime (in kilobytes and/or seconds) of IPSec SAs created by a crypto map |
session-key | Defines encryption and authentication keys for a crypto map |
use | Uses the configured IP access list |
no | Removes or reverts crypto map IPSec manual settings |
