meshpoint-qos-policy
Configures a set of parameters that
defines the meshpoint QoS policy.
The
WiNG 7.1.X release does not support Meshpoint configuration on AP5XX model access
points. This feature will be supported in future releases.
Configured on WiNG 7.1.X controller
and pushed to the following WiNG 5.9.X APs:
- Access Points — AP7502, AP7522,
AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8543, AP8533
Syntax
meshpoint-qos-policy <MESHPOINT-QOS-POLICY-NAME>
Parameters
<MESHPOINT-QOS-POLICY-NAME> |
Specify the meshpoint QoS policy name. If a policy with the specified
name does not exist, it is created. |
nx9500-6C8809(config)#meshpoint-qos-policy test
nx9500-6C8809(config-meshpoint-qos-test)#?
Mesh Point QoS Mode commands:
accelerated-multicast Configure accelerated multicast streams address and
forwarding QoS classification
no Negate a command or set its defaults
rate-limit Configure traffic rate-limiting parameters on a
per-meshpoint/per-neighbor basis
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no
Removes an existing meshpoint QoS policy |
For more
information on Meshpoint QoS policy configuration, see
Meshpoint Policy.
