nova (management-policy)
Enables HTML5-based NOVA UI. The following rules apply:
Syntax
nova
no nova
Parameters
None
The following example shows the current settings for the management policy named test-cw. In this example, nova is enabled, which is the default setting.
vx9000-3C6F18(config-management-policy-test-cw)#?
Management Mode commands:
  aaa-login                Set authentication for logins
  allowed-locations        Add allowed locations
  banner                   Define a login banner
  flash-ui                 Enable FLASH UI
  ftp                      Enable FTP server
  http                     Hyper Text Terminal Protocol (HTTP)
  https                    Secure HTTP
  idle-session-timeout     Configure idle timeout for a configuration session
                           (GUI or CLI)
  ipv6                     IPv6 management access restriction
  no                       Negate a command or set its defaults
  nova                     Enable NOVA UI
  passwd-retry             Lockout user if too many consecutive login failures
  privilege-mode-password  Set the password for entering CLI privilege mode
  rest-server              Enable rest server for device on-boarding
                           functionality
  restrict-access          Restrict management access to the device
  snmp-server              SNMP
  ssh                      Enable ssh
  t5                       T5 configuration
  telnet                   Enable telnet
  user                     Add a user account
  clrscr                   Clears the display screen
  commit                   Commit all changes made in this session
  do                       Run commands from Exec mode
  end                      End current mode and change to EXEC mode
  exit                     End current mode and down to previous mode
  help                     Description of the interactive help system
  revert                   Revert changes
  service                  Service Commands
  show                     Show running system information
  write                    Write running configuration to memory or terminal
In the following example, nova is first disabled using the no command, then it is re-enabled.
vx9000-3C6F18(config-management-policy-test-cw)#no nova
vx9000-3C6F18(config-management-policy-test-cw)#show context
management-policy test-cw
 no telnet
 no http server
 no nova
 no flash-ui
 https server
 rest-server
 ssh
 ssh enable-weak-mac-algo 1
vx9000-3C6F18(config-management-policy-test-cw)#nova
 no telnet
 no http server
 nova
 no flash-ui
 https server
 rest-server
 ssh
In the following example, nova and https server are enabled. In this case, NOVA UI is reachable on port 443.
 no telnet
 no http server
 nova
 no flash-ui
 https server
 rest-server
 ssh
In the following example, nova and http server are enabled. In this case, NOVA UI is reachable on port 80.
vx9000-3C6F18(config-management-policy-test-cw)#http server
vx9000-3C6F18(config-management-policy-test-cw)#no https server
 no telnet
 http server
 nova
 no flash-ui
 no https server
 rest-server
 ssh
Related Commands
no Disables NOVA UI access on the device
