no (bgp-ext-community-list)
Removes an existing deny or permit extended community rule from this extcommunity list
Syntax
no [deny|permit] extcommunity expanded <LINE>
no [deny|permit] extcommunity standard [rt|soo] <COMMUNITY-NUMBER>
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes a deny or permit expanded extended community rule from this community list
The following example shows the extended community ‘test‘ settings before the ‘no‘ command is executed:
nx9500-6C8809(config-bgp-extcommunity-list-test)#show context
bgp extcommunity-list test
 permit extcommunity standard rt 300:03
 deny extcommunity standard rt 200:12
nx9500-6C8809(config-bgp-extcommunity-list-test)#no permit extcommunity standard 300:03
The following example shows the extended community ‘test‘ settings after the ‘no‘ command is executed:
