meshpoint-device <MESHPOINT-NAME>
meshpoint-device | Configures the AP as a meshpoint device and sets its parameters |
<MESHPOINT-NAME> | Specify the name of the meshpoint to configure the AP with (should be existing and configured). |
In the following examples, the meshpoint is applied to an access point profile.
nx9500-6C8809(config)#profile ap8432 testAP8432 nx9500-6C8809(config-profile-testAP8432)#meshpoint-device TestMeshpoint nx9500-6C8809(config-profile-testAP8432-meshpoint-TestMeshpoint)#? Mesh Point Device Mode commands: acs Configure auto channel selection parameters exclude Exclude neighboring Mesh Devices hysteresis Configure path selection SNR hysteresis values monitor Event Monitoring no Negate a command or set its defaults path-method Path selection method used to find a root node preferred Configure preferred path parameters root Set this meshpoint as root root-select Root selection method parameters clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile-testAP8432-meshpoint-TestMeshpoint)#
ap8432-070235(config-device-74-67-F7-07-02-35)#meshpoint-device test ap8432-070235(config-device-74-67-F7-07-02-35-meshpoint-test)#? Mesh Point Device Mode commands: acs Configure auto channel selection parameters exclude Exclude neighboring Mesh Devices hysteresis Configure path selection SNR hysteresis values monitor Event Monitoring no Negate a command or set its defaults path-method Path selection method used to find a root node preferred Configure preferred path parameters root Set this meshpoint as root root-select Root selection method parameters clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal ap8432-070235(config-device-74-67-F7-07-02-35-meshpoint-test)#
The following table summarizes the meshpoint-device configuration mode commands.
Command | Description |
acs (meshpoint-device-config) | Enables Automatic Channel Selection (ACS) on this meshpoint device (access point) |
exclude (meshpoint-device-config) | Excludes neighboring mesh devices |
hysteresis (meshpoint-device-config) | Configures path selection SNR hysteresis values on this meshpoint-device (Access Point) |
monitor (meshpoint-device-config) | Enables monitoring of critical resource and primary port links on a meshpoint device |
path-method (meshpoint-device-config) | Configures the method used to select the path to the root node in a mesh network |
preferred (meshpoint-device-config) | Configures the preferred path parameters for a meshpoint device |
root (meshpoint-device-config) | Configures a meshpoint device as the root meshpoint |
root-select (meshpoint-device-config) | Configures this meshpoint device as the cost root |
no (meshpoint-device-config) | Negates the commands for a meshpoint device or resets values to default |
