This command also configures the external guest registration and validation server details. If using an external server to perform guest registration, authentication and accounting, use this command to configure the external server‘s IP address/hostname. When configured, access points and controllers forward guest registration requests to the specified registration server. In case of EGuest deployment, this external resource should point to the EGuest registration server.
registration [device|device-OTP|external|user]
registration [device|device-OTP|user] group-name <RAD-GROUP-NAME> {agreement-refresh <0-144000>|
expiry-time <1-43800>}
      registration external [follow-aaa|host]
registration external follow-aaa {send-mode [http|https|udp]}
      registration external host <IP/HOSTNAME> {proxy-mode|send-mode}
      registration external host <IP/HOSTNAME> {proxy-mode [none|through-controller|
through-rf-domain-manager|through-centralized-controller]|send-mode [https|https|udp]}
      | registration | Enables dynamic guest-user registration and validation. This option is disabled by default. |
| external | Specifies that the guest registration is handled by an external resource. Access points/controllers send registration requests to the external registration server. |
| follow-aaa | Uses an AAA policy to point to the guest registration, authentication, and
                accounting server. When used, guest registration is handled by the RADIUS server
                specified in the AAA policy used in the WLAN context. In case of EGuest deployment, the RADIUS authentication and accounting server configuration in the AAA policy should point to the EGuest server. The use of ‘follow-aaa‘ option is recommended in EGuest replica-set deployments. For more information on enabling the EGuest server, see eguest-server (VX9000 only) (profile config mode). For more information on configuring an EGuest deployment, see configuring ExtremeGuest captive portal.  |
| send-mode [https|https|udp] | Optional. Specifies the protocol used to forward registration requests to the
                external AAA policy servers. The options are:
      | registration | Configures dynamic guest registration and validation parameters. This option is disabled by default. |
| host <IP/HOSTNAME> | Specifies the external registration server‘s IP address or hostname. When configured, access points/ controllers forward guest registration requests to the external registration server specified here. |
| proxy-mode {none| through-controller| through-rf-domain-manager|through-centralized-controller} | Optional. Specifies the proxy mode. If a proxy is needed
                for connection, specify the proxy mode as through-controller, through-rf-domain. If
                no proxy is needed, select none.
 After specifying the proxy-mode, optionally specify the protocol used to send the requests to the external registration server host.  |
| send-mode [https|https|udp] | Optional. Specifies the communication protocol used. The
                options are;
{agreement-refresh <0-144000>|expiry-time <1-43800>}
| [device|device-OTP| user] | Configures the mode used to register guest users of this
                WLAN. Options include device, external, user, and device-OTP
 If using any one of the above modes of registration, specify the RADIUS group to which the registered device or user is to be assigned post authentication.  |
| group-name <RAD-GROUP-NAME> | Configures the RADIUS group name to which registered
                users are associated. When left blank, users are not associated with a RADIUS group.
| expiry-time <1-43800> | Optional. Configures the amount of time, in hours,
                before registered addresses expire and must be re-entered
| agreement-refresh <0-144000> | Optional. Sets the time, in minutes, after which an
                inactive user has to refresh the WLAN‘s terms of agreement. For example, if the
                agreement refresh period is set to 1440 minutes, a user, who has been inactive for
                more than 1440 minutes (1 day) is served the agreement page, and is allowed access
                only after refreshing the terms of agreement.
nx9500-6C8809(config-wlan-test)#registration user group-name guest agreement-ref
resh 14400 expiry-time 2000
      nx9500-6C8809(config-wlan-test)#show context wlan test ssid test bridging-mode local encryption-type none authentication-type none registration user group-name guest expiry-time 2000 agreement-refresh 14400 nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Disables dynamic user registration and removes associated configurations. Also disables forwarding of user information to an external device. |
