This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.time-it <COMMAND>
time-it <COMMAND>
                         time-it <COMMAND>  |
                         Verifies the time taken by a particular command to execute and provide a result
ap505-13403B#time-it config terminal Enter configuration commands, one per line. End with CNTL/Z. That took 0.00 seconds.. ap505-13403B(config)#
