controller-assisted-mobility
Enables controller or service platform assisted mobility to determine a wireless client‘s VLAN assignment. When enabled, a controller or service platform‘s mobility database is used to assist in roaming between RF Domains. This option is disabled by default.
Syntax
Parameters
None
ap505-13403B(config-wlan-test)#controller-assisted-mobility
ap505-13403B(config-wlan-test)#show context
wlan test
 ssid test
 vlan 1
 bridging-mode local
 encryption-type ccmp
 authentication-type sae-psk
 protected-mgmt-frames optional
Related Commands
no (wlan-config-mode) Disables controller or service platform assisted mobility to determine a wireless client‘s VLAN assignment
