This command only initiates the search process. It does not return the actual GPS coordinates. To view the coordinates, execute the following command:show gps coordinates {on <DEVICE-NAME>}
Access Point — AP7662
gps search [start|stop] {on <DEVICE-NAME>}
gps search [start|stop] | Triggers the GPS hardware to start or stop the GPS coordinates
search process
Note: Unless
explicitly stopped, the GPS coordinates search continues at
regular intervals.
on <DEVICE-NAME> | Optional. Specifies the AP whose geographic coordinates are to be
determined. Use this option if executing the command on the
controller or virtual controller to which the AP is adopted.
Note: If you do
not specify a device name, the system initiates the search on
the logged device. And if the logged device is not an AP7662
model access point, an error message returns.
ap7662-8BDE4D#gps search start Started GPS Search, please check back after some time. ap7662-8BDE4D#
ap7662-8BDE4D#show gps coordinates GPS Search is in progress. Last location recorded at UTC time : Mon Apr 23 22:10:54 2018 : Latitude : 13.036N Longitude : 77.3827E ap7662-8BDE4D#
