rest <URL>
rest <URL>
| rest <URL> | Configures the third-party server's URL
ap8432-070235(config-ble-data-export-policy-test)#rest https://test.com/12/
ap8432-070235(config-ble-data-export-policy-test)#show context ble-data-export-policy test rest https://test.com/12/ ap8432-070235(config-ble-data-export-policy-test)#
The following example shows the configurations required to enable BLE data forwarding:
ap8432-070235(config-profile-test-if-bluetooth1)#mode le-sensor
ap8432-070235(config-profile-test-if-bluetooth1)#no shutdown
ap8432-070235(config-profile-test-if-bluetooth1)#show context interface bluetooth1 no shutdown mode le-sensor ap8432-070235(config-profile-test-if-bluetooth1)#
This enables the AP as a BLE sensor.
NOC-NX9500(config-ble-data-export-policy-test)#rest https://test.com/12/
NOC-NX9500((config-sensor-policy-test)#rssi-interval-duration 30
NOC-NX9500(config-rf-domain-ble)#use ble-data-export-policy test
This enables BLE data forwarding to the external, third-party server specified in the policy.
NOC-NX9500(config-rf-domain-ble)#use sensor-policy test
When applied, BLE data is forwarded at the interval specified in the sensor policy.
| no (ble-data-export-commands) | Removes the REST endpoint URL configuration |
| sensor-policy | Documents the Sensor policy configuration commands |
