ssid
      Configures the WLAN's SSID
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Parameters
         ssid <SSID>
                     | <SSID> |
                     Specify the WLAN's SSID. The WLAN SSID is case sensitive and
                        alphanumeric. It's length should not exceed 32 characters. |
         nx9500-6C8809(config-wlan-test)#ssid testWLAN1
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid testWLAN1
 bridging-mode local
 encryption-type none
authentication-type none
 protected-mgmt-frames mandatory
 radius vlan-assignment
 wing-extensions wmm-load-information
 client-load-balancing probe-req-intvl 5ghz 5
 client-load-balancing band-discovery-intvl 2
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
 proxy-arp-mode strict
 broadcast-dhcp validate-offer
 shutdown on-unadoption
 http-analyze controller
