interface-config-radio-instance
Enables access point to change its channel of operation in order to terminate rogue devices. The radio should be configured to provide WLAN service.
This option is enabled by default.
WiNG access points use Smart RF to perform off-channel scans. Therefore, ensure that a Smart RF policy is configured and applied to the access points RF Domains to enable them perform rogue detection and termination.wips airtime-termination [allow-channel-change|spectrum-management-strict]
wips airtime-termination allow-channel-change | Enables access point to change its channel of operation (to that of the rogue device) in order to terminate the rogue device |
spectrum-management-strict | Enables the processing of spectrum management capability of an AP before performing air-termination |
nx9500-6C8809(config-profile-testAP510-if-radio1)#wips air-termination allow-channel-change
no (radio-interface-config-command) | Disables access point to change its channel of operation in order to terminate rogue devices |
