antenna-id (ap510e)
Profile Config Commands
Configures the antenna ID on an AP510e model access point profile and device. Use this command to specify the antenna types used with the external antennas.
The ExtremeMobility AP510e access point is a dual-radio access point, with eight, external Wi-Fi antennas grouped into: group-1 (antenna ports 1 to 4) and group-2 (antenna ports 5 to 8).
The antenna-id parameter, specifies the antenna type used in the group-1 and/or group-2 antenna ports. The antenna ports used by the AP to receive/transmit traffic depends on the software mode its running. Refer, following table for information on the antenna group used for the different software modes:
Antenna Ports
Software Mode 2.4/5G Antennas: 1, 2, 3, 4 5G Antennas: 5, 6, 7, 8
Mode 1
  • Radio 1 - 2.4 GHz WLAN
  • Radio 2 - 5 GHz WLAN
Note: This mode requires only FOUR, dual-band antennas connected to ANT sockets 1 to 4.
Note: If using this mode, configure antenna-id only for the group 1 antennas.
Dual-band 2.4 GHz/5 GHz None
Mode 2
  • Radio 1 - 2.4/5 GHz Sensor
Note: This mode requires FOUR, dual-band antennas connected to ANT sockets 1 to 4, and FOUR, 5G-band antennas connected to ANT sockets 5 to 8.
Note: If using this mode, configure antenna-id for both group 1 and group 2 antennas.
Dual-band 2.4 GHz/5 GHz 5 GHz
Mode 3
  • Radio 1 - 5 GHz WLAN
Note: Requires FOUR, 5G-band antennas connected to ANT sockets 1 to 4, and FOUR, 5G-band antennas connected to ANT sockets 5 to 8.
5 GHz 5 GHz
Supported in the following platform
Syntax
antenna-id external [group-1|group-2] <ANTENNA-TYPE>
Parameters
antenna-id Selects the antenna group to use.
external States the antenna is external
group-1 Configures the antenna type used in the group-1 antenna ports (1 to 4).
Note: Group-1 antenna configuration is required for all three software modes.
Note: Refer to the table above for the supported software modes and the corresponding antenna configurations.
group-2 Configures the antenna type used in the group-2 antenna ports (5 to 8 ).
Note: Group-2 antenna configuration is ONLY required for software modes 2 & 3.
antenna-type Configures the antenna type used
The antenna types supported for 'group-1' and 'group-2' antenna ports are: ai-dq04360s, ml-2452-apa2-01, ml-2452-apa2-02, ml-2452-hpa5-036, ml-2452-hpag4a6-01, ml-2452-hpag5a8-01, ml-2452-pna5-01r, ml-2452-pna7-01r, ml-2452-pta4m4-036, ml-2452-sec6m4-036, ws-ai-dq05120.
By default no antenna-type is associated with the group-1 and group-2 antenna ports and the radio is disabled.
Usage Guidelines:
Following is the supported software modes for the AP510e access point radios:
Software Mode 1
  • Radio 1: Set to 2.4 GHz WLAN, Channels 1 - 11 in the 20 MHz /40 MHz bandwidths
  • Radio 2: Set to 5 GHz WLAN, Channels 36 - 165 in the 20 MHz /40 MHz /80 MHz /160 MHz
Software Mode 2
  • Radio 1: Set to 2.4/5 GHz Sensor
Software Mode 3
  • Radio 1: Set to 5 GHz, Channels 36 - 64 in the 20 MHz /40 MHz /80 MHz /160 MHz bandwidths
  • Radio 2: Set to 5 GHz, Channels 100 - 165 in the 20 MHz /40 MHz /80 MHz /160 MHz bandwidths
ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#antenna-id ?
  group-1  Configure the antenna id on antenna group 1 (2.4/5GHz dual band
           antenna)
  group-2  Configure the antenna id on antenna group 2 (5GHz single band
           antenna)
ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#antenna-id group-1 ?
  ai-dq04360s         AI-DQ04360S Dual Band, Four Input Omni, 36 Inch Cable
  default             Internal antenna for internal SKU, no antenna for
                      external SKU
  ml-2452-apa2-01     ML-2452-APA2-01 3dBi/4.85dBi, dual band, black
  ml-2452-apa2-02     ML-2452-APA2-02 3dBi/4.85dBi, dual band, white
  ml-2452-hpa5-036    ML-2452-HPA5-036 3dBi/5dBi, dual band, outdoor, white
  ml-2452-hpag4a6-01  ML-2452-HPAG4A6-01 4dBi/7.3dBi, N-type male, dual band,
                      outdoor, white
  ml-2452-hpag5a8-01  ML-2452-HPAG5A8-01
  ml-2452-pna5-01r    ML-2452-PNA5-01R 2.4/5 GHz, Outdoor, Panel, 5 dBi, Beam
                      Width: E-Plane: 65 degrees, H-Plane: 120 degrees
  ml-2452-pna7-01r    ML-2452-PNA7-01R 8/12dBi 68deg Panel
  ml-2452-pta4m4-036  ML-2452-PTA4M4-036 4dBi/5 dBi, 4 port, dual band
  ml-2452-sec6m4-036  ML-2452-SEC6M4-036 DUAL POLARIZED DUAL BAND WIDE BEAM
                      DIRECTIONAL ANTENNA WITH 36 INCH CABLE
  ws-ai-dq05120       WS-AI-DQ05120 DUAL POLARIZED DUAL BAND WIDE BEAM
ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#antenna-id group-2 ai-dq04360s
ap510-133C9B(config-device-94-9B-2C-13-3C-9B)#show context
ap510 94-9B-2C-13-3C-9B
 use profile default-ap510
 use rf-domain default
 hostname ap510-133C9B
 no mint mlcp vlan
 no mint mlcp ip
 antenna-id group-1 ai-dq04360s
 interface radio1
 interface vlan1
  description "Virtual Interface for LAN by Wizard"
  ip address 192.162.4.159/24
  ip address zeroconf secondary
  no ip dhcp client request options all
 no virtual-controller
 no rf-domain-manager capable
 no adoption-mode
Related Commands
no Removes the antenna-id configuration on the selected AP510e profile and device.
