meshpoint
Creates a new meshpoint and enters its
configuration mode. Use this command to select and configure existing meshpoints.
Meshpoint configuration is not supported
on 802.11ax access points. This feature will be supported in future
releases.
Supported in the following
platforms:
- Access Points — AP7522, AP7532,
AP7562, AP7612, AP7632, AP7662, AP8432, AP8533
Syntax
meshpoint [<MESHPOINT-NAME>|containing <WORD>]
Parameters
<MESHPOINT-NAME> |
Specify the meshpoint name. If the meshpoint does not exist, it is
created. |
containing <WORD> |
Selects existing meshpoints containing the sub-string <WORD> in
their names |
nx9500-6C8809(config)#meshpoint testMeshpoint
nx9500-6C8809(config-meshpoint-testMeshpoint)#?
Mesh Point Mode commands:
allowed-vlans Set the allowed VLANs
beacon-format The beacon format of this meshpoint
control-vlan VLAN for meshpoint control traffic
data-rates Specify the 802.11 rates to be supported on this meshpoint
description Configure a description of the usage of this meshpoint
force Force suboptimal paths
meshid Configure the Service Set Identifier for this meshpoint
neighbor Configure neighbor specific parameters
no Negate a command or set its defaults
root Set this meshpoint as root
security-mode The security mode of this meshpoint
shutdown Shutdown this meshpoint
use Set setting to use
wpa2 Modify ccmp wpa2 related parameters
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no
Removes an existing meshpoint |
