no [allowed-vlans|beacon-format|control-vlan|description|force|meshid|root| security-mode|shutdown]
no data-rates [2.4GHz|5GHz|6GHz]
no force peer-paths-through-root
no neighbor inactivity-timeout
no use [aaa-policy|meshpoint-qos-policy]
no wpa2 [eap|key-rotation|psk]
no wpa2 eap [auth-type|identity|peap-mschapv2|tls trustpoint]
no wpa2 key-rotation [broadcast|unicast]
no wpa2 psk
no service allow-ht-only
no <PARAMETERS>
                         no <PARAMETERS>  |
                     Removes or reverts this meshpoint settings to default based on the parameters passed |
nx9500-6C8809(config-meshpoint-test)#show context meshpoint test description "This is an example of a meshpoint description" meshid TestingMeshPoint shutdown beacon-format mesh-point control-vlan 1 allowed-vlans 1,10-16,18-23 neighbor inactivity-timeout 300 data-rates 2.4GHz bgn data-rates 5GHz an security-mode psk wpa2 psk 0 Test Company wpa2 key-rotation unicast 1200 wpa2 key-rotation broadcast 600 root nx9500-6C8809(config-meshpoint-test)#
nx9500-6C8809(config-meshpoint-test)#no allowed-vlans
         nx9500-6C8809(config-meshpoint-test)#no beacon-format
         nx9500-6C8809(config-meshpoint-test)#no control-vlan
         nx9500-6C8809(config-meshpoint-test)#no description
         nx9500-6C8809(config-meshpoint-test)#no meshid
         nx9500-6C8809(config-meshpoint-test)#no root
         nx9500-6C8809(config-meshpoint-test)#no security-mode
meshpoint test
 control-vlan 1
 data-rates 5GHz an
 security-mode none
 no root
         nx9500-6C8809(config-meshpoint-test)#no data-rates 2.4GHz
         nx9500-6C8809(config-meshpoint-test)#no data-rates 5GHz
         nx9500-6C8809(config-meshpoint-test)#show context meshpoint test beacon-format mesh-point control-vlan 1 neighbor inactivity-timeout 300 security-mode none wpa2 psk 0 Test Company wpa2 key-rotation unicast 1200 wpa2 key-rotation broadcast 600 no root nx9500-6C8809(config-meshpoint-test)#
rfs4000-229D58(config-meshpoint-test)#show context meshpoint test meshid test beacon-format mesh-point control-vlan 1 security-mode none no root force peer-paths-through-root rfs4000-229D58(config-meshpoint-test)#
rfs4000-229D58(config-meshpoint-test)#no force peer-paths-through-root
         rfs4000-229D58(config-meshpoint-test)#show context meshpoint test meshid test beacon-format mesh-point control-vlan 1 security-mode none no root rfs4000-229D58(config-meshpoint-test)#
