Configures meshpoint device parameters. This feature is configurable in the profile and device configuration modes.
meshpoint-device <MESHPOINT-NAME>
meshpoint-device <MESHPOINT-NAME> | Configures meshpoint device parameters
For VMM (Vehicular Mounted Modem) access points or other mobile devices, set the path selection method as mobile-snr-leaf in the config-meshpoint-device mode. For more information, see path-method (meshpoint-device-config).
nx9500-6C8809(config-profile-TestAP8533)#meshpoint-device test nx9500-6C8809(config-profile-TestAP8533-meshpoint-test)#? Mesh Point Device Mode commands: acs Configure auto channel selection parameters exclude Exclude neighboring Mesh Devices hysteresis Configure path selection SNR hysteresis values monitor Event Monitoring no Negate a command or set its defaults path-method Path selection method used to find a root node preferred Configure preferred path parameters root Set this meshpoint as root root-select Root selection method parameters clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile-TestAP8533-meshpoint-test)#
no | Removes a specified meshpoint |
