Enables message logging and configures logging settings. When enabled, the profile logs individual system events to a user-defined log file or a syslog server. Message logging is disabled by default.
Enabling message logging is recommended, because system event logs can be analyzed to determine an overall pattern that may be negatively impacting performance.
This command can also be executed in the device configuration mode.
logging [aggregation-time <1-60>|host [<IPv4>|<IPv6>] {port <1-65535>}|on]
| logging | Enables message logging and configures logging settings |
| aggregation-time <1-60> | Sets the number of seconds for aggregating repeated messages. This is the interval at which system events are logged on behalf of this profile. The shorter the interval, the sooner the event is logged.
| host [<IPv4>|<IPv6>] {port <1-65535>} | Configures a remote host to receive log messages. Defines numerical (non DNS) IPv4 or IPv6 addresses for external resources where logged system events can be sent on behalf of the profile (or device). A maximum of four entries can be made.
| on | Enables the logging of system messages |
logging [buffered|console|syslog|forward] [<0-7>|emergencies|alerts|critical| errors|warnings|notifications|informational|debugging]
| buffered | Sets the buffered logging level |
| console | Sets the console logging level |
| syslog | Sets the syslog server‘s logging level |
| forward | Forwards system debug messages to the wireless controller or service platform |
| [<0-7>|alerts| criticail|debugging| emergencies|errors| informational| notifications| warnings] | The following keywords are common to the buffered, console, syslog, and forward parameters. All incoming messages have different severity levels based on their importance. The severity level is fixed on a scale of 0 - 7.
logging facility [local0|local1|local2|local3|local4|local5|local6|local7]
| facility [local0|local1| local2|local3|local4| local5|local6|local7] | Enables the syslog to decide where to send the incoming message There are 8 logging facilities, from syslog0 to syslog7.
NOC-NX9500(config-profile-testNX9000)#logging facility local4 NOC-NX9500(config-profile-testNX9000)#show context include-factory | include log ging no logging on logging aggregation-time 0 logging console warnings logging buffered warnings logging syslog warnings logging facility local4 logging forward errors no l2tpv3 logging no dpi logging on dpi logging level notifications NOC-NX9500(config-profile-testNX9000)#
| no | Disables logging on this profile |
