no <PARAMETER>
no <PARAMETERS> | The no command is common across all configuration modes and sub modes. It resets or reverts settings based on the mode in which executed. For example, when executed in the AAA policy configuration mode, it allows you to reset or revert a specific AAA policy settings. Similarly, when executed in the global configuration mode, it only resets or reverts settings configured in the global configuration mode. |
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
Global Config mode: No command options
ap8432-070235(config)#no ? aaa-policy Delete a aaa policy aaa-tacacs-policy Delete a aaa tacacs policy alias Alias ap7522 Delete an AP7522 access point ap7532 Delete an AP7532 access point ap7562 Delete an AP7562 access point ap7602 Delete an AP7602 access point ap7612 Delete an AP7612 access point ap7622 Delete an AP7622 access point ap7632 Delete an AP7632 access point ap7662 Delete an AP7662 access point ap8432 Delete an AP8432 access point ap8533 Delete an AP8533 access point application Delete an application application-group Delete an application-group application-policy Delete an application policy association-acl-policy Delete an association-acl policy auto-provisioning-policy Delete an auto-provisioning policy bonjour-gw-discovery-policy Disable Bonjour Gateway discovery policy bonjour-gw-forwarding-policy Disable Bonjour Gateway Forwarding policy bonjour-gw-query-forwarding-policy Disable Bonjour Gateway Query Forwarding policy captive-portal Delete a captive portal client-identity Client identity (DHCP Device Fingerprinting) client-identity-group Client identity group (DHCP Fingerprint Database) crypto-cmp-policy CMP policy customize Restore the custom cli commands to default device Delete multiple devices device-categorization Delete device categorization object dhcp-server-policy DHCP server policy dhcpv6-server-policy DHCPv6 server related configuration dns-whitelist Delete a whitelist object event-system-policy Delete a event system policy ex3500-qos-class-map-policy Delete a ex3500 qos class-map policy ex3500-qos-policy-map Delete a ex3500 qos policy-map firewall-policy Configure firewall policy global-association-list Delete a global association list igmp-snoop-policy Remove device onboard igmp snoop policy inline-password-encryption Disable storing encryption key in the startup configuration file ip Internet Protocol (IP) ipv6 Internet Protocol version 6 (IPv6) ipv6-router-advertisement-policy IPv6 Router Advertisement related configuration l2tpv3 Negate a command or set its defaults mac MAC configuration management-policy Delete a management policy meshpoint Delete a meshpoint object meshpoint-qos-policy Delete a mesh point QoS configuration policy nac-list Delete an network access control list nsight-policy Delete a nsight policy passpoint-policy Delete a passpoint configuration policy password-encryption Disable password encryption in configuration profile Delete a profile and all its associated configuration radio-qos-policy Delete a radio QoS configuration policy radius-group Local radius server group configuration radius-server-policy Remove device onboard radius policy radius-user-pool-policy Configure Radius User Pool rf-domain Delete one or more RF-domains and all their associated configurations roaming-assist-policy Delete a roaming-assist policy role-policy Role based firewall policy routing-policy Policy Based Routing Configuratino rtl-server-policy Delete a rtl server policy schedule-policy Delete a schedule policy sensor-policy Delete a sensor policy smart-rf-policy Delete a smart-rf-policy url-filter Delete a url filter url-list Delete a URL list web-filter-policy Delete a web filter policy wips-policy Delete a wips policy wlan Delete a wlan object wlan-qos-policy Delete a wireless lan QoS configuration policy service Service Commands ap8432-070235(config)#
Priv Exec mode: No command options
ap8432-070235(config)#exit ap8432-070235#no ? adoption Reset adoption state of the device (& all devices adopted to it) captive-portal Captive portal commands crypto Encryption related commands debug Debugging functions logging Modify message logging facilities page Toggle paging service Service Commands terminal Set terminal line parameters upgrade Remove a patch wireless Wireless Configuration/Statistics commands ap8432-070235#
User Exec mode: No command options
ap8432-070235#disable ap8432-070235>no ? adoption Reset adoption state of the device (& all devices adopted to it) captive-portal Captive portal commands crypto Encryption related commands debug Debugging functions logging Modify message logging facilities page Toggle paging service Service Commands terminal Set terminal line parameters wireless Wireless Configuration/Statistics commands ap8432-070235>
no | User Exec no command |
no | Priv Exec no command |
no | Global Config no command |
