no (mac-acl)
Negates a command or sets its default
Syntax
no [deny|disable|permit]
no [deny|permit] [<SOURCE-MAC> <SOURCE-MAC-MASK>|any|host <SOURCE-HOST-MAC>]
[<DEST-MAC> <DEST-MAC-MASK>|any|host <DEST-HOST-MAC>] (dot1p <0-7>,type [8021q|<1-65535>|
aarp|appletalk|arp|ip|ipv6|ipx|mint|rarp|wisp],vlan <1-4095>) log (rule-precedence <1-5000>)
{(rule-description <LINE>)}
no disable [deny|permit] <RULE-PARAMETERS>
Parameters
no [deny|permit]
Removes a deny or permit rule from the MAC ACL
Specify the source MAC address and mask
any
Select ‘any‘ if the rule is applicable to any source MAC address
Specify the source host‘s exact MAC address.
Specify the destination MAC address and mask
any
Identifies all devices as the destination to deny/permit access
Specify the destination host‘s exact MAC address.
dotp1p <0-7>
Specify the 802.1p priority value from 0 -7.
type [8021q|<1-65535>| aarp|appletalk|arp|ip|ipv6|ipx|mint|rarp|wisp]
Specify the EtherType value.
vlan <1-4095>
Specify the VLAN ID.
log
Select log, if the rule has been configured to log records in case of a match.
mark [8021p <0-7>| dscp <0-63>]
This is specific to the MAC ACL permit rule. Marks packets that match the ACL rule
8021p <0-7> – Modifies 802.1p VLAN user priority from 0 - 7
dscp <0-63> – Modifies DSCP TOS bits in the IP header from 0 - 63
Specify the rule precedence. The rule with the specified rule precedence is removed from the MAC ACL.
Optional. Provide the description configured for the rule.
Removes a disabled deny or permit rule from the selected IP access list
<RULE-PARAMETERS>
Enter the exact parameters used when configuring the rule.
rule-precedence <1-5000> rule-description <LINE>}
Specify the precedence assigned to this disabled deny/permit rule.
  • rule-description – Optional. Specify the rule description.
Note: The system removes the disabled rule from the selected ACL.
nx9500-6C8809(config-mac-acl-test)#show context
mac access-list test
 permit host 11-22-33-44-55-66 any log mark 8021p 3 rule-precedence 600
 permit host 22-33-44-55-66-77 host 11-22-33-44-55-66 type ip log rule-precedence 610
 deny any host 33-44-55-66-77-88 log rule-precedence 700
nx9500-6C8809(config-mac-acl-test)#no deny any host 33-44-55-66-77-88 log rule-precedence 700
