roaming-assist-policy
      Configures a roaming assist policy that enables access
         points to assist wireless clients in making roaming decisions, such as which access point
         to connect, etc.
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         roaming-assist-policy <ROAMING-ASSIST-POLICY-NAME>
      Parameters
                     | <ROAMING-ASSIST-POLICY-NAME> |
                     Specify the roaming-assist policy name. If a policy with the specified
                        name does not exist, it is created. |
         nx9500-6C8809(config)#roaming-assist-policy test
nx9500-6C8809(config-roaming-assist-policy-test)#?
Roaming Assist Mode commands:
  action               Configure action - action is deauth / log /
                       assisted-roam
  aggressiveness       Configure the roaming aggressiveness for a wireless
                       client
  detection-threshold  Configure the detection threshold - when exceeded,
                       client monitoring starts
  disassoc-time        Configure the disassociation time - time after which a
                       disassociation is sent
  handoff-count        Configure the handoff count - number of times client
                       can exceed handoff threshold
  handoff-threshold    Configure the handoff threshold - when exceeds an
                       action is taken.
  monitoring-interval  Configure the monitoring interval - interval at which
                       client monitoring occurs
  no                   Negate a command or set its defaults
  sampling-interval    Configure the sampling interval - interval at which
                       client rssi values are checked
  clrscr               Clears the display screen
  commit               Commit all changes made in this session
  end                  End current mode and change to EXEC mode
  exit                 End current mode and down to previous mode
  help                 Description of the interactive help system
  revert               Revert changes
  service              Service Commands
  show                 Show running system information
  write                Write running configuration to memory or terminal
      Related Commands
                     | no
                     Removes an existing roaming-assist-policy |
