Configures the WiNG controller (wireless controller or service platform) adoption settings
Adoption is the process a controller or service platform uses to discover available access points and/or peer controllers/service platforms, establish an association and provision the adopted device. Adoption settings are configurable and supported within a profile and applied to all devices supported by the profile.
Use this command to add a controller to a pool and group. This command also enables and disables adoption on controllers, and specifies the device types that can be adopted by a controller.
controller [adopted-devices|adoption|group|hello-interval|vlan|host]
controller adopted-devices [aps {controllers}|controllers {aps}|external-devices|external-devices-monitoring-only]
controller adoption
controller [group <CONTROLLER-GROUP-NAME>|vlan <1-4094>]
controller hello-interval <1-120> adjacency-hold-time <2-600>
controller host [<IPv4>|<IPv6>|<HOSTNAME>] {ipsec-secure|level|pool|remote-vpn-client}
controller host [<IPv4>|<IPv6>|<HOSTNAME>] {ipsec-secure} {gw [<IP>|<HOSTNAME>]}
controller host [<IPv4>|<IPv6>|<HOSTNAME>] {level [1|2]|pool <1-2> level [1|2]} {ipsec-secure {gw [<IP>|<HOSTNAME>]}|remote-vpn-client}
controller host [<IPv4>|<IPv6>|<HOSTNAME>] {remote-vpn-client}
controller | Configures the WLAN‘s controller adoption settings |
adopted-devices | Configures the types of device (AP/controller) this controller can adopt |
aps {controllers} | Enables the
adoption of network access points by this controller. This option is enabled
by default.
All adopted devices (referred to as adoptee) receive complete configuration from the adopting controller (referred to as adopter). |
controllers {aps} | Enables the
adoption of peer controllers by this controllers
A controller cannot be configured as an adoptee and an adopter simultaneously. In other words, an adopted controller (adoptee) cannot be configured to adopt another controller. Use the no > controller > adopted-devices command to remove this setting. |
external-devices | Enables adoption
of external devices by this controller. This option is disabled by
default. When enabled, a WiNG controller can adopt and manage T5 controllers and EX3500 switches (using the IPX operating system) within a WiNG managed device subnet. This setting is disabled by default. To disable T5 or EX3500 adoption, use
t This feature is supported only on NX9500, NX9510, NX9600, and VX9000 platforms. |
external-devices-monitoring-only | Enables only monitoring of external devices by this controller or service platform. This option is disabled by default. |
controller adoption
controller adoption | Enables the
adoption of the logged device (wireless controller or service platform) by
other controllers. This option is disabled by default. Use the no > controller > adoption command to disable adoption. |
group <CONTROLLER-GROUP-NAME> | Configures the
wireless controller or service platform group
vlan <1-4094> | Configures the
wireless controller or service platform VLAN
controller | Configures the WLAN‘s controller settings |
hello-interval <1-120> | Configures the
hello-interval in seconds. This is the interval between consecutive hello
packets exchanged between AP and wireless controller or service platform.
adjacency-hold-time <2-600> | Configures the
adjacency hold time in seconds. This is the time since the last received
hello packet, after which the adjacency between wireless controller or
service platform and AP is lost, and the link is re-established.
host [<IPv4>|<IPv6>| <HOSTNAME>] | Configures
wireless controller or service platform‘s IPv4/IPv6 address or hostname
ipsec-secure {gw [<IP>| <HOSTNAME>]} | Optional.
Enables Internet Protocol Security (IPSec) peer authentication on the
connection (link) between the adopting devices. This option is disabled by
default.
If the gateway‘s IP address or hostname is not specified, the system assumes the logged controller as the IPSec gateway. |
wireless controller or service platform‘s IPv4/IPv6 address or name
level [1|2] | The following
keywords are common to the ‘IP‘, ‘IPv6‘, and ‘hostname‘ parameters: Optional. After providing the wireless controller or service platform‘s address, optionally select one of the following routing levels:
pool <1-2> level [1|2] | The following
keywords are common to the ‘IP‘, ‘IPv6‘, and ‘hostname‘ parameters: Optional. Sets the wireless controller or service platform‘s pool
{ipsec-secure {gw [<IP>| <HOSTNAME>]}| remote-vpn-client} | After specifying
the routing level and or device‘s pool, you can optionally specify the
following:
The controller uses remote VPN tunnel for this traffic. If multiple controller hosts are configured, either all the hosts should use remote-vpn-client or none. When enabled, an MLCP connection is not initiated until remote VPN connection is UP and virtual IP, DNS server, source route, etc. are installed on the AP. |
remote-vpn-client | Forces MLCP to
use remote VPN connection on the controller The controller uses remote VPN tunnel for this traffic. If multiple controller hosts are configured, either all the hosts should use remote-vpn-client or none. When enabled, an MLCP connection is not initiated until remote VPN connection is UP and virtual IP, DNS server, source route, etc. are installed on the AP. |
nx9500-6C8809(config-profile-default-ap8533)controller group test nx9500-6C8809(config-profile-default-ap8533)#controller host 1.2.3.4 pool 2 nx9500-6C8809(config-profile-default-ap8533)#show context profile ap8533 default-ap8533 no autoinstall configuration no autoinstall firmware crypto isakmp policy default crypto ipsec transform-set default esp-aes-256 esp-sha-hmac .......................................................... interface ge4 ip dhcp trust qos trust dscp qos trust 802.1p use firewall-policy default controller host 1.2.3.4 pool 2 controller group test service pm sys-restart --More-- nx9500-6C8809(config-profile-default-ap8533)# nx9500-6C8809(config-profile-testAP8432)#controller adopted-devices aps controllers nx9500-6C8809(config-profile-testAP8432)#show context profile ap8432 testAP8432 autoinstall configuration .................................................................... logging on service pm sys-restart router ospf controller adopted-devices aps controllers nx9500-6C8809(config-profile-testAP8432)#
no | Disables or reverts settings to their default |
