interface-config-radio-instance
Enables dynamic chanin selection. When enabled, the radio can dynamically change the number of transmit chains used (uses a single chain/antenna for frames at non-11n transmit rates). This option is enabled by default.
dynamic-chain-selection {strict}
         | dynamic-chain-selection {strict} | Enables dynamic
                        chain selection.
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#dynamic-chain-selection
| no (radio-interface-config-command) | Uses the configured transmit antenna mode for all clients |
