ip (wlan-config-mode)
Configures IPv4 settings
Syntax
ip [arp|dhcp]
ip arp [header-mismatch-validation|trust]
ip dhcp trust
Parameters
ip arp Configures the IP settings for ARP packets
header-mismatch-validation Verifies mismatch of source MAC address in the ARP and Ethernet headers. This option is enabled by default.
trust Sets ARP responses as trusted for a WLAN/range. This option is disabled by default.
ip dhcp trust
ip dhcp Configures the IP settings for DHCP packets
trust Sets DHCP responses as trusted for a WLAN/range. This option is disabled by default.
nx9500-6C8809(config-wlan-test)#ip dhcp trust
nx9500-6C8809(config-wlan-test)#show context
wlan test
 description TestWLAN
 ssid test
 bridging-mode local
 encryption-type tkip-ccmp
 authentication-type eap
 accounting syslog host 172.16.10.4 port 2
 data-rates 2.4GHz gn
 client-load-balancing probe-req-intvl 5ghz 5
 client-load-balancing band-discovery-intvl 2
 captive-portal-enforcement fall-back
 ip dhcp trust
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
 enforce-dhcp
 broadcast-dhcp validate-offer
 http-analyze controller
Related Commands
no (wlan-config-mode) Resets IP ARP or DHCP trust parameters to default. ARP trust is disabled, ARP mismatch verification is enabled, or DHCP trust is disabled.
