| icon iso-lang <ISO-LANG-CODE> |
              Configures an icon representing the OSU provider
                  - iso-lang <ISO-LANG-CODE> – Identifies the language by its ISO 639 language
                    code (for example, ‘chi-chinese‘ or ‘spa-spanish‘). By default the language is
                    set to English. If specifying the image file name and path in any language other
                    than English, specify the ISO language code.
              | width <0-65535> |
              Configures the icon‘s width in pixels
                  - <0-65535> – Specify a value from 0 - 65535 pixels.
              | height <0-65535> |
              Configures the icon‘s height in pixels
              | mime-type <FILE-MIME-TYPE> |
              Configures a string describing the icon‘s standard mime
                type. The MIME associates filename extensions with a MIME type. A MIME enables a
                fallback on an extension and are frequently used by Web servers.
                  - <FILE-MIME-TYPE> – Specify the icon‘s mime type.
              | file [<IMAGE-FILE-NAME/PATH>|<FILE-NAME>] |
              Configures the location and name of the image file
                  - <IMAGE-FILE-NAME/PATH> – Specify the path and filename (255 character
                    maximum). For example, flash:/icon.png
                  - <FILE-NAME> – Use this option to specify the filename in the flash:/
                    directory
