detection-threshold
Specifies the detection-threshold determining when a client is monitored
Syntax
detection-threshold <-100--40>
Parameters
Configures the detection threshold value determining when a client is monitored. The clients with bad RSSI values are monitored more frequently.
  • <-100--40> – Specify the RSSI value from -100 dBm - -40 dBm. The default is -75 dBm.
nx9500-6C8809(config-roaming-assist-policy-test)#detection-threshold -90
nx9500-6C8809(config-roaming-assist-policy-test)#show context
roaming-assist-policy test
 aggressiveness medium-high
 action log
Related Commands
no Removes the configured detection threshold details
