dns-whitelist
Configures a DNS whitelist. A DNS whitelist is a list of allowed DNS destination IP addresses pre-approved to access a controller, service platform, or access point managed captive portal.
Syntax
dns-whitelist <DNS-WHITELIST-NAME>
Parameters
Specify the DNS whitelist name. If the whitelist does not exist, it is created.
nx9500-6C8809(config)#dns-whitelist test
nx9500-6C8809(config-dns-whitelist-test)#?
DNS Whitelist Mode commands:
  no       Negate a command or set its defaults
  permit   Match a host
  clrscr   Clears the display screen
  commit   Commit all changes made in this session
  end      End current mode and change to EXEC mode
  exit     End current mode and down to previous mode
  help     Description of the interactive help system
  revert   Revert changes
  service  Service Commands
  show     Show running system information
  write    Write running configuration to memory or terminal
Related Commands
no
Removes an existing DNS Whitelist
