enforcement-time
purview-application-policy
Configures an enforcement time in days and hours. The enforcement time is applicable only to those rules, within the application policy, that do not have a schedule policy associated. By default an application policy is enforced on all days.
Schedule policies enforce allow/deny/mark/rate-limit rules at different time periods. If absence of a schedule policy, application policy rules are enforced at the enforcement-time specified within the policy. For more information on configuring a schedule policy, see schedule-policy.
Syntax
enforcement-time days [sunday|monday|tuesday|wednesday|thursday|friday|saturday|
all|weekends|weekdays] {start-time <HH:MM> end-time <HH:MM>}
Parameters
enforcement-time days Enforces this application policy on only on the days specified here
  • sunday – Enforces the policy only on Sundays
  • monday – Enforces the policy only on Mondays
  • tuesday – Enforces the policy only on Tuesdays
  • wednesday – Enforces the policy only on Wednesdays
  • thursday – Enforces the policy only on Thursdays
  • friday – Enforces the policy only on Fridays
  • saturday – Enforces the policy only on Saturdays
  • all – Enforces the policy on all days. This is the default setting.
  • weekends – Enforces the policy only on weekends
  • weekdays – Enforces the policy only on weekdays
In case no enforcement time is specified, the application policy is enforced on all days (i.e., always active).
If using schedule policies with the allow/deny/mark/rate-limit rules, the best practice would be to keep the application policy active at all time (i.e., retain the default enforcement-time setting of ‘all‘).
start-time <HH:MM> end-time <HH:MM> Optional. Configures this application policy‘s enforcement period
  • start-time – Configures the start time. This is the time at which the application policy enforcement begins.
  • end-time – Configures the end time. This is the time at which the application policy enforcement ends.
    • <HH:MM> – Specify the start and end time in the HH:MM format.
nx9500-6C8809(config-purview-app-policy-PurAppPolicy)#enforcement-time days weekends start-time 10:30 end-time 20:00
nx9500-6C8809(config-purview-app-policy-PurAppPolicy)#show context
purview-application-policy PurAppPolicy
 description "This application policy allows Applie_Streaming packets on weekends."
 allow application Apple_Streaming precedence 1
Related Commands
no Removes this application policy‘s enforcement period
