excluded-address [<IP>|<HOST-ALIAS-NAME>|range]
excluded-address <IP>
excluded-address <HOST-ALIAS-NAME>
excluded-address range [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]
                         <IP>  |
                         Adds a single IP address to the exclude address list  |
                         <HOST-ALIAS-NAME>  |
                         Adds a host alias. The host alias is mapped to a host‘s IP address. The host identified by the host alias is added to the excluded address list. The host alias should be existing and configured. Note: A
                           network host alias maps a name to a single network
                           host. For example, ‘alias host $HOST 1.1.1.100‘. In
                           this example the host alias is ‘$HOST‘ and it maps to
                           a single host ‘1.1.1.100‘. For more information, see
                              alias.
excluded-address [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]
                         range [<START-IP>| <START-HOST-ALIAS- NAME>] [<END-IP>| <END-HOST-ALIAS- NAME>]  |
                     Adds a range of IP addresses to the excluded
                        address list. Use one of the following options to provide the first IP
                        address in the range:
 Use one of the following options to provide the last IP address in the range:
 The host aliases should be existing and configured.  |
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#excluded-address range 192.168.13.25 192.168.13.28
         rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#show context dhcp-pool testPool network 192.168.13.0/24 address 192.168.13.4 class dhcpclass1 ddns server 192.168.13.9 ddns domainname WID ddns multiple-user-class excluded-address range 192.168.13.25 192.168.13.28 domain-name documentation bootfile test.txt default-router 192.168.13.8 192.168.13.9 dns-server 192.168.13.19 rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#
| no |
                         Removes the exclude IP addresses settings  |
