no (event-system-policy-config-mode)
Negates an event monitoring configuration
Syntax
no event <EVENT-TYPE> <EVENT-NAME> [email|forward-to-switch|snmp|syslog] [default|on|off]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes event monitoring and message forwarding activity based on the parameters passed
The system stops network monitoring for the occurrence of the specified event and no notification is sent if the event occurs.
rfs4000-229D58(config-event-system-policy-TestPolicy)#event ap adopted syslog default
rfs4000-229D58(config-event-system-policy-TestPolicy)#no event ap adopted syslog
Related Commands
event Configures the action taken for each event
