dynamic-vlan-assignment
      Enables dynamic VLAN assignment on
         this WLAN, and adds or removes VLANs for the selected WLAN. Configure this feature to allow
         an override to the WLAN configuration. If, as part of the authentication process, the
         RADIUS server returns a client's VLAN-ID in a RADIUS Access-Accept packet, and this feature
         is enabled, all client traffic is forward on that VLAN. If disabled, the RADIUS server
         returns VLAN-ID is ignored and the WLAN‘s VLAN configuration is used. For more information,
         see vlan. This option is disabled by default.
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         dynamic-vlan-assignment allowed-vlan <VLAN-ID>
      Parameters
                     | dynamic-vlan-assignment allowed-vlan |
                     Enables dynamic VLAN assignment and configures a list of VLAN IDs or
                        VLAN alias allowed access to the WLAN |
                     | <VLAN-ID> |
                     Specify the list of VLAN IDs or the VLAN alias
                        names. For example, 10-20, 25, 30-35, $guest. For
                        example, 10-20, 25, 30-35, $guest.  For information on
                           VLAN aliases, see alias .
         ap505-13403B(config-wlan-test)#dynamic-vlan-assignment allowed-vlans 2,3,4
         ap505-13403B(config-wlan-test)#show context
wlan test
 ssid test
 vlan 1
 bridging-mode local
 encryption-type ccmp
 authentication-type sae-psk
 dynamic-vlan-assignment allowed-vlans 2-4
 protected-mgmt-frames optional
 controller-assisted-mobility
 dpi metadata http
