no (aaa-tacacs-policy-config-mode-command)
Removes this AAA TACACS policy settings or revrets to default values
Syntax
no [accounting|authentication|authorization]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes this AAA TACACS policy settings or revrets to default values, based on the parameters passed
The following example shows the AAA-TACACS policy ‘test' settings before the ‘no' commands are executed:
nx9500-6C8809(config-aaa-tacacs-policy-test)#show context
aaa-tacacs-policy test
 authentication directed-request
 accounting server preference authorized-server-number
 authorization allow-privileged-commands
 accounting auth-fail
  accounting commands
nx9500-6C8809(config-aaa-tacacs-policy-test)#no authentication directed-request
nx9500-6C8809(config-aaa-tacacs-policy-test)#no accounting auth-fail
nx9500-6C8809(config-aaa-tacacs-policy-test)#no authorization allow-privileged-commands
The following example shows the AAA-TACACS policy ‘test' settings after the ‘no' commands are executed:
 accounting commands
