lock-rf-mode
interface-config-radio-instance
Retains user configured RF mode settings for the selected radio. This option is disabled by default.
Syntax
lock-rf-mode
Parameters
None
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#lock-rf-mode
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
  description "Primary radio to use"
  channel 1
  data-rates b-only
  beacon period 50
  beacon dtim-period bss 1 5
  beacon dtim-period bss 2 2
  beacon dtim-period bss 3 5
  beacon dtim-period bss 4 5
  beacon dtim-period bss 5 5
  beacon dtim-period bss 6 5
  beacon dtim-period bss 7 5
  beacon dtim-period bss 8 5
  beacon dtim-period bss 9 5
  beacon dtim-period bss 10 5
  beacon dtim-period bss 11 5
  beacon dtim-period bss 12 5
  beacon dtim-period bss 13 5
  beacon dtim-period bss 14 5
  beacon dtim-period bss 15 5
  beacon dtim-period bss 16 5
  antenna-gain 12.0
  guard-interval long
  aggregation ampdu tx-only
  aeroscout forward
  ekahau forward ip 172.16.10.1 port 3
  antenna-mode 2x2
  antenna-diversity
  airtime-fairness prefer-ht weight 6
  lock-rf-mode
  extended-range 15
--More--
Related Commands
no (radio-interface-config-command) Allows Smart RF to change a radio‘s RF mode settings
