interface-config-radio-instance
Configures the antenna mode (the number of transmit and receive antennas) on the access point
This command sets the number of transmit and receive antennas on the access point. The 1x1 mode is used for transmissions over just the single -A- antenna, 1xALL is used for transmissions over the -A- antenna and all three antennas for receiving. The 2x2 mode is used for transmissions and receipts over two antennas for dual antenna models. The default setting is dynamic based on the access point model deployed and its transmit power settings.
antenna-mode [1*1|1*ALL|2*2|3*3|default]
antenna-mode [1*1|1*ALL|2*2|default]
antenna-mode | Configures the antenna mode |
1*1 | Uses only antenna A to receive and transmit |
1*ALL | Uses antenna A to transmit and receives on all antennas |
2*2 | Uses antennas A and C for both transmit and
receive Note: AP505i and AP510i are dual antenna
access points.
3*3 | Uses antenna A, B, and C for both transmit and receive |
default | Uses default antenna settings. This is the default setting. |
For STBC feature support, the antenna-mode should not be configured to 1*1.ap505-133E1C(config-profile-testap505-if-radio2)#antenna-mode 2x2 ap505-133E1C(config-profile-testap505-if-radio2)#show context interface radio2 mesh client antenna-elevation 5.0 antenna-gain 12.0 aggregation ampdu tx-only aeroscout forward ip 1.23.4.56 port 300 antenna-mode 2x2 antenna-diversity ap505-133E1C(config-profile-testap505-if-radio2)#
no (radio-interface-config-command) | Resets the radio antenna mode (the number of transmit and receive antennas) to its default |
