class
Creates a policy map class and enters
its configuration mode. The policy map class is a traffic classification upon which a policy
can act.
- Service Platforms — NX 7510, NX 95XX, NX 96XX
Syntax
class <EX3500-QoS-CLASS-MAP-POLICY-NAME>
Parameters
class <EX3500-QoS-CLASS-MAP-POLICY-NAME> |
Specify the EX3500 QoS class map policy‘s name (should
be existing and configured) |
nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap)#class dscp
nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap-pmap-class-dscp)#?
commands:
no Negate a command or set its defaults
police Defines a policer for classified traffic
set Classify IP traffic
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
set |
Sets CoS value, per-hop behavior (PHB) value, and IP DSCP value in
matching packets |
police |
Configures an enforcer for classified traffic |
no (ex3500-qos-policy-map) |
Removes this traffic classification‘s settings |
