ebgp-multihop (bgp-neighbor-config)
Enables eBGP Multihop on this BGP neighbor. When enabled, allows neighbor connection to be established between two eBGP neighbors that are not directly connected to each other. Use this command to configure the maximum number of hops possible between two such eBGP neighbors. This option is disabled by default.
Syntax
ebgp-multihop <1-255>
Parameters
ebgp-multihop <1-255> Configures the maximum number of hops that can be between eBGP neighbors not directly connected to each other.
  • <1-255> – Specify a value from 1 - 255. The default is 255.
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#ebgp-multihop 20
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   advertisement-interval 100
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
   disable-connected-check
   dont-capability-negotiate
   ebgp-multihop 20
Related Commands
no (bgp-neighbor-config) Disables eBGP Multihop on this BGP neighbor
