use
      Uses CRM (Critical Resource
            Monitoring) to monitor link status
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         use critical-resource-monitoring
      Parameters
                     | use critical-resource-monitoring |
                     Uses CRM to monitor the status of a link. Selecting this option
                        determines the disposition of the route-map next hop via monitored critical
                        resources. Link monitoring is the function used to determine a potential
                        fail over to the secondary next hop. This option is enabled by
                        default. |
         nx9500-6C8809(config-routing-policy-testpolicy)#use critical-resource-monitoring
