route-map
Creates a dynamic
BGP (Border Gateway Protocol) route map and enters its
configuration modeBGP route maps are used by network administrators to
define rules controlling redistribution of routes between routers and
routing processes. These route maps are also used to control and modify
routing information.
- Service Platforms — NX5500,
NX7500, NX9500, NX9600
- Virtual Platforms — CX9000, VX9000
Syntax
route-map <ROUTE-MAP-NAME>
Parameters
route-map <ROUTE-MAP-NAME> |
Creates a new BGP route map and enters its configuration
mode |
nx9500-6C8809(config)#route-map test
nx9500-6C8809(config-dr-route-map-test)#?
Route Map Mode commands:
deny Add a deny route map rule to deny set operations
no Negate a command or set its defaults
permit Add a permit route map rule to permit set operations
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no |
Removes an existing dynamic BGP route map |
