no
interface-config-port-channel-instance
Removes or reverts to default this port-channel interface‘s settings
Syntax
no beacon [description|duplex|ip|ipv6|port-channel|qos|shutdown|spanning-tree| speed|switchport|use]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes or reverts to default this port-channels interface‘s settings based on the parameters passed
  • <PARAMETERS> – Specify the parameters.
The following example shows the port-channel interface‘s interface settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#show context
description "This port-channel is for enabling dynamic LACP."
  speed 100
  duplex full
  switchport mode trunk
  switchport trunk native vlan 1
  no switchport trunk native tagged
  switchport trunk allowed vlan 1
  use ip-access-list in BROADCAST-MULTICAST-CONTROL
  ipv6 nd trust
  ipv6 nd header-mismatch-validation
  spanning-tree portfast
  spanning-tree bpduguard enable
  spanning-tree bpdufilter enable
  spanning-tree mst 1 port-priority 1
  spanning-tree mst 1 cost 20000
  ip arp trust
  port-channel load-balance src-dst-mac
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#no duplex
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#no ip arp trust
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#no ipv6 nd trust
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#no port-channel load-balance
The following example shows the port-channel interface‘s interface settings after the ‘no‘ commands are executed:
 interface port-channel1
  speed 100
  no qos trust dscp
